E pistons in DE motor
Old Jul 22, 2004 | 12:22 PM
nomadtrash's Avatar
What are the choices for high compression pistons? I have heard rumors that the E pistons in the DE motor will give 11.6 to 1 compression. Is this true? Is there any machining required?
Thanks,
Nomad Trash
68 SRL311 U20 Solex
Old Jul 22, 2004 | 01:38 PM
ArticDragon's Avatar
Yeah, it's true. Even though the compression in the E is lower than the DE, putting the E pistons in the DE will raise the compression to about 11:1. What's with the pic?
Old Jul 22, 2004 | 03:03 PM
nomadtrash's Avatar
My E-Modified autocross car. It is a 68 Datsun Roadster. 1500 pounds with a 200hp U20 motor. It scoots pretty well on Hoosier 22x9x13 slicks. I plan on installing a KA24DE because it is 25 years newer technology and isn't as fragile as the U20. Try rebuilding one of those U20's 4 times a year. Talk about expensive.
I've seen that there may be a difference between the early e pistons and the late ones. Which gives the most CR? My neighbor sells race gas so I'm not too concerned with detonation. The car only holds 3 gallons and only runs on the track.
Thanks,
Old Jul 26, 2004 | 08:19 AM
4984 5fsdskfvjdsntr4's Avatar
Banned
the earlier flat top pistons give u more cr, it has to be from a (early 89)built in 88 240sx or u can get them new from the dealer, but i forgot the part#
240sxgod
Nov 17, 2003 09:51 PM
duckman240sx
Sep 8, 2003 01:02 AM
Jonas
Mar 6, 2003 08:04 PM
S13 Slide
Dec 13, 2002 02:23 PM
RNN14
Mar 1, 2002 02:32 PM
