ECU's GOING OUT ONE AFTER ANOTHER!!!
Old Apr 9, 2007 | 09:25 AM
homesliceisj's Avatar
I jus recently had a no spark problemt and i did some part swaping with a friend and we figured out it was the ecu... Well i replaced the ecu and it ran great but after abotu 3 start ups the car would not start again and once again NO SPARK... and once again its the ECU. What is causeing this problem and what should i do about it this is an exdpensive problem???
Old Apr 9, 2007 | 02:21 PM
did you upgrade your fuel injectors?
Old Apr 9, 2007 | 07:16 PM
No i did not... But would that have anything to do with a no spark problem coming form the ecu??
Old Apr 9, 2007 | 07:27 PM
LA_phantom_240's Avatar
I wouldnt think so. I personally think theres somehting else at work here besides the ECU. Do some sherlock work and try to find another source.
Old Apr 9, 2007 | 07:28 PM
sr91240's Avatar
i didnt know sherlock holmes worked on cars lol
Old Apr 9, 2007 | 07:54 PM
DriftX's Avatar
shorted out ignition control module, ignitor for short. Try replacing that, im in the same problem myself. I'll let you know.
Old Apr 9, 2007 | 07:56 PM
My bad reason I asked was if he switched to low impedance injectors (from stock Hi-impedance) it might have made the ECU malfunction.
Old Apr 11, 2007 | 06:32 AM
Is ther anything i can do besides replacing the whole ecu??? Because everything else seems to work it jus wont allow the car to spark... I jus dont wanna pay for another ecu if i have other options..
Old Apr 11, 2007 | 07:43 AM
re037's Avatar
check main fuse block? grounds?
Old Apr 12, 2007 | 03:27 PM
BigVinnie's Avatar
How do you know it's not a bad coil???
Or that you just arent grounded???
kenjimatic
Mar 12, 2008 06:36 AM
iluvdrifting
Dec 22, 2005 12:32 PM
