Engine Clean up. Removing EGR and TB lines, BASICS
Old Apr 2, 2007 | 02:54 PM
FuriousZ's Avatar
Arrow Engine Clean up. Removing EGR and TB lines, BASICS
I just got a 93 coupe and so far i have been making sure that its reliable.
So far i have mostly cleaned the car, since i don't think they took good care of it. (or as much as i will)
I want to remove some engine components that i don't need.
I was thinking the EGR (exhaust gas recirculation valve),
AIV.
TB coolant lines,
what ever else i can remove.
(PLEASE TELL ME OF THINGS THAT I CAN REMOVE FROM MY NEW S13)
I have been searching but i can't get a clean writeup on the goods or bads of it.
Someone PLEASE help me.
Tell me if i should remove them, and if there is, point me to a write up on removing things that i don't need in my engine bay.
I will post pics of my car and the process once I get some clear responses.
ENRIQUe
i don't know if this pic is going to show thats what i want to remove! and what ever you all think i can remove!
Old Apr 2, 2007 | 03:35 PM
LA_phantom_240's Avatar
Clutch fan, stock coil with an MSD unit, battery reloaction. All of those will free up some much needed work room in our s13s. Good luck with your build.
Old Apr 2, 2007 | 04:10 PM
yea take that shiet out, remove egr, clutch fan, a/c if your not a weenie baby, im sure theres some more things to remove that im not thinking of.
Old Apr 2, 2007 | 05:24 PM
!!!Eliminate the creature features they are for weenie babies hahaha!!!
Old Apr 2, 2007 | 05:33 PM
if you don't mind the heat or the cold you can do away with the heater core, ac compressor and lines for these two.
they're not engine compartments but you can do w/o them
Old Apr 2, 2007 | 05:36 PM
pm sent.............
Old Apr 2, 2007 | 10:00 PM
I need the little bit of a/c my 240 has left.. louisiana heat + black car = zomg its hot.
But yeah, all emissions and related vaccuum lines, simplify the ignition system, make cooling better and youve already got a clean bay.
Old Apr 3, 2007 | 07:22 PM
donteventry's Avatar
take out the charcol canister!!! whooo hoooo ****kk emissions haha
Old Apr 3, 2007 | 07:25 PM
weenie baby! lolj/p
Old Apr 3, 2007 | 08:54 PM
but then you'll need to do something about the vacuum lines. i don't think you can just block them off either.
Old Apr 3, 2007 | 09:42 PM
you can plug those no problem.. remove the lines and add caps to the hard vacuum lines...
most important vacuum's are main air idler and brake booster
Old Apr 3, 2007 | 09:46 PM
onemoreblock's Avatar
ah egr will keep your cyc temps down. and keep you from producing too much nox. which is a good thing unless you dont have emmison laws and in that case **** it remove your cat and replace it with a test pipe. full 3in exhaust and turbo the ka24de
Old Apr 3, 2007 | 10:22 PM
yea i have to worry about being blown up by children bombers in Iraq soon lol emissions is not the most of my worries.
Old Apr 4, 2007 | 05:54 AM
Lawlz Airman Jackson, you so silly hahahaha.
Old Apr 4, 2007 | 08:43 AM
FuriousZ's Avatar
pics
first some pics of my new car
