Engine shaking side to side??? HELP
Old Jun 19, 2005 | 05:09 PM
Komedy's Avatar
my 91' KA is automatic. what causes the engine to shake side to side so violently??
ive checked motor mounts
changed spark plugs
spark plug wires
distrubitor cap.
for some reason the motor stops shaking when i pull off the second spark plug wire.
starts shaking violently when i plug it back in.
can it be my timing?
please help, need car to get to work.
Old Jun 20, 2005 | 03:13 AM
wikd240's Avatar
you are miss firing for some reason... it could be your timing is all messed up... or your plug wires are in the wrong spot... re check your firing order and then check your timing...
Old Jun 20, 2005 | 11:51 AM
Joel SX's Avatar
It could be the timing or the wires like wikd240 said. other reason might be that there's somethign wrong with a valve or fuel to that piston making it act erradicly. If everything fails, take it to mr. mechanick and he'll change a cable to some other place for 400$......dam mechanicks allways riping people off for silly S**t. If the problem was after you changed the wires, then its defenetly the wires, or wiring. if it was before then it can be that or more serius. my dad sold this ugly ford probe becuz it was shaking out of control from 1.3K to 3K and the mechanick said that it was a valve not sitting right or something with the valves and that they had to take the head off and all the seals and posibly a spring set, wich was a inmense amount to pay for a 86 ford. He sold it saying it needed spark plug wires. If thats your case then you might want to take the oportunity to upgrade to some racing spring valves and all you can afford now while they are taking it apart. Good luck!!
Old Jun 20, 2005 | 03:51 PM
chiroke's Avatar
umm broken motor mount??
Old Jun 21, 2005 | 03:16 AM
wikd240's Avatar
ummm... did you read the part where he checked the motor mount??? that was listed above so i did not say anything about it... a busted motor mount will allow the motor to jump under acceleration more than make it shake...
Old Jun 22, 2005 | 11:15 PM
BigVinnie's Avatar
If it is a rough unbalanced idle it could be a VACUUM line it's that simple.....................
Old Jun 22, 2005 | 11:29 PM
ReigH's Avatar
it could be a bad fuel injector
Old Jun 23, 2005 | 04:51 PM
Komedy's Avatar
yup 3rd fuel injector. changed it, now its all good
Old Jun 23, 2005 | 04:52 PM
Komedy's Avatar
anyone know of a good place that sells sr20dets and install for a good price in so cal???
Old Jun 23, 2005 | 07:15 PM
nsn240's Avatar
^ why did you post that in here?
Old Jun 23, 2005 | 07:17 PM
Fast1One's Avatar
To kill two birds with one stone lol....Hes right though...search for your answer first then post another thread. Im sure you shouldnt have too, it sounds like a common question.
Old Jun 24, 2005 | 04:48 AM
tryiian's Avatar
Shouldnt there be billboards, tv/radio ads, and sidewalk vendors selling T-shirts all mentioning where to get/install Japanese market engine in California (south esp.) by now? Have you guys still not managed to win the fight against the legal system with smog and all that, yet?
Mr. guy, just stop the next S chassis you hear driving by that makes a nice whistle and goes "psh" and ask him where to go. I`m sure they can`t be that hard to find.
namster180
Oct 7, 2005 07:50 PM
2forties
Aug 2, 2005 01:47 AM
2forties
May 18, 2005 04:01 PM
jackyliem
Aug 15, 2004 03:08 AM
jackyliem
Dec 20, 2003 12:18 PM
