a few question about an engine swap
Old Jun 16, 2009 | 01:57 PM
pourinitup's Avatar
i have a 90 ka24e and i just blew a head gasket, so i decided ill finally do that swap ive been waiting for since i bought the car
i got this offer for a 97 ka24de with the wiring harness and i think he also said tranny
will i need anything else going from e to de?, will i really need to use the other tranny? and will it be farely straight forward? my only concern is the s13 ka24e to the s14 if im correct ka24de
i also am going to find the how to swap faq somewhere on this site
thanks in advance for any help
Old Jun 16, 2009 | 02:17 PM
Nickmerrone's Avatar
why not just buy a 5 dollar head gasket? hahaha. i have like 10 extra new ones.
Im doing the same swap right now though.
Old Jun 16, 2009 | 07:42 PM
pourinitup's Avatar
well the guy said he would give me the engine wiring harness and tranny and the engine has 60k miles supposedly for 500 which is around what i was looking to spend, is this all im going to need for the swap? or will i need anything else?
and do i need to swap trannys or can i use my current one?
Old Jun 16, 2009 | 07:54 PM
dude, just replace the head gasket..it'll be so much less work and money.
Old Jun 16, 2009 | 09:26 PM
pourinitup's Avatar
it may be a cracked block i havent checked yet but the engine has numerous problems i just want to start building the DE
work is no problem i like working on cars and as long as thats all i need for the swap money isnt really an issue either
Old Jun 17, 2009 | 11:45 AM
djsilver's Avatar
You don't have to change the wiring harness or the transmission. The 97 is an OBDII system and the harness won't fit your ECU but your harness will connect right up to the necessary parts of the S14 motor. The problem areas are the power steering (pump and reservoir are on opposite sides and hoses are different) and air conditioning, if you still have it. The S14 is an R134 system with a bigger compressor and larger fittings. Your best bet would be to swap the whole A/C system but you can get custom connections made if you want.
Old Jun 18, 2009 | 06:07 PM
pourinitup's Avatar
ok so if i read that how to on the swap it should mention how to do all that too?
if you have the page bookmarked (anybody) can you post the link to it
ronnycage
Mar 30, 2007 08:46 PM
Atown 240
Jan 8, 2006 10:16 AM
zeroGripS13
Aug 5, 2005 09:12 PM
SilviaJai
Sep 23, 2003 07:36 AM
Condom_Sense
Jul 8, 2002 01:39 PM
