fuel and air mixture?
Old May 14, 2004 | 02:19 PM
war's Avatar
war
I was wondering if the fuel and air mixture was messed up if that could cause black smoke to blow out my exhuast at high rpm. If not anyone know of anything else that could cause this. I just had pacesetter headers and a pacesetter high flow cat put on about 2 months ago.
Old May 15, 2004 | 10:15 PM
BoogiepopJDM's Avatar
Becaue of the high flow setting that you have now with your exhaust system, you might be noticing that you might actually be burning oil, I'm not saying its because of your headers and cat this is happening, but its rather letting you see whats going on with your engine because of the nice exhaust flow you have. i couldnt really tell you if its because of an unbalanced air/fuel mixure. but what i can tell you is that black smoke is a sign of your engine burning oil. if you wanna be sure its not your air/fuel mix install a air/fuel meter and see if it has a nice transaction from (lean to stoich to rich) its a fast one but make sure its aims more towards rich while cruising. Good luck bro.
Old May 16, 2004 | 12:43 AM
LTSCUDRFT's Avatar
it's blue smoke that means your burnig oil not black,
black smoke mean's that you are probaly runing ritch.
and when you get a AFR gauge buy a wide band O2 sensor and instal it where your headers go from 2-1. it will give you a more accurate reading.
Old May 16, 2004 | 01:31 AM
war's Avatar
war
if I am running rich how do I fix it?
Old May 16, 2004 | 11:29 AM
LTSCUDRFT's Avatar
buy a new O2 sensor, it should help.
Old May 16, 2004 | 05:05 PM
war's Avatar
war
What can cause an engine to burn oil?
Old May 16, 2004 | 10:00 PM
LTSCUDRFT's Avatar
bad piston rings, valve seals. those are probably the most common. how much oil are you burning anyway? also if you rev your engine into higher RPM's (above 4500) alot you will consume alot more oil than if you "grandma" your car.
Old May 17, 2004 | 05:44 PM
war's Avatar
war
Also my car putters at low rpm driving but when I get on it, its fine. Any Ideas?
Old May 17, 2004 | 10:47 PM
LTSCUDRFT's Avatar
bad egr valve, not sure what else.
seanchris16
Jul 20, 2007 12:25 PM
DaTurk
Apr 8, 2007 03:16 AM
DaTurk
Jan 28, 2007 10:54 PM
Strizzy
Aug 18, 2003 09:47 PM
Dom
Feb 10, 2002 12:03 AM
