Head or Engine?
Head or Engine?
Just bought 240sx 1989 for $300. Looks good but does not run Head burned up when they drove it with no water. Fix or Replace Engine 180,000 miles on it. Also cannot open rear lid, lock in-op how do you open it? Want to do it cheap not much in cash. Need to buy new radiator and clutch also. Need some advice on what to do.
I reckon hyjnx is correct.
Basic rebuilt kit with timing kit and oil pump = $500 (if you do it yourself)
KA with half the miles that runs = 300-400.
Although if you rebuild you'll know it's done right (if you did it right), buying a used engine can sometimes be trouble.
Dr.
Dr.
Called around found KA from $400 to 600. I live in a house no garage it's winter cold out even if I'm in Georgia it still sucks working outside. Also got to do Clutch job. You are right $500 for a RE build kit on the head plus head work because I think they melted it down. Engine swap would be the cheapest.
70Challenger
Jun 25, 2006 02:28 PM
revolt-rise
Aug 16, 2005 08:43 PM
Plastic Phork
Mar 14, 2005 03:59 PM
SilviaJai
Sep 23, 2003 07:36 AM
