Head Swap
Old Nov 1, 2006 | 09:59 PM
jdmbugi's Avatar
Head Swap
Does the head of KA24DE dual overhead camm bolt in to KA24E single head block?
Old Nov 2, 2006 | 09:12 AM
tehott240's Avatar
im not positive but i dont think that it will. i think the bolts are in different spots.
Old Nov 4, 2006 | 08:54 AM
sularus65's Avatar
This has been done, I believe that you have to do some work on the front timing covers, but it will work. It raises your compression to something like 11.1-11.7:1 Definately not something you are going to run on 89 octane. Spend sometime doing some research on several different forums like 240sx forums and ******** and you should find the info you need.
Jason
Old Nov 4, 2006 | 09:25 AM
LA_phantom_240's Avatar
It will from what ive read, but you will need to swap over the entire timing chain system from the DE as well. If you have a DE motor, why not just use the pistons off of the E, instead of going through all the trouble with the head and timing.
70Challenger
Jun 25, 2006 02:28 PM
revolt-rise
Aug 16, 2005 08:43 PM
izzen
Jun 18, 2004 06:16 PM
2240sx's
Oct 9, 2003 11:48 AM
konseiEva
Nov 9, 2002 02:23 PM
