help me please stall question
Old Jan 24, 2004 | 03:35 PM
Hella 240's Avatar
I have a 1992 240sx with an automatic trans and everyonce in a while when u start to push the gas from a stop it will stall out. When you try to start it agin it wont. You have to play with it for about 10 minutes before it will start up. as long as you keep it above 1500 rmp it runs fine. it idles ok and the performance seems to be ok. it doesnt matter if it is warm or cold it seems to happen randomly. anyone know what it could be?
Old Jan 26, 2004 | 08:29 AM
Hella 240's Avatar
No one have any ideas? My guess is its the thottle body and MAF.
Old Jan 26, 2004 | 08:44 AM
crimsontide240's Avatar
i would say MAF, bad injectors, O2 sensor, dirty throttle body?
crimsontide
Old Jan 26, 2004 | 03:36 PM
tommyboy's Avatar
Maybe it could be your fuel pump starting to go out. And you should check any vacuum lines too, since they could do something like this. Or even a loose clump of dirt in the fuel filter that could move around and occasionally block fuel flow
Old Jan 28, 2004 | 04:51 PM
Ballzac19's Avatar
I had the same problem on my 91 5-speed, but it would cut out at any rpm range. check your crank angle sensor, ignition coil, distributor, and maf in that order. I had a bad distributor
jackyliem
Dec 20, 2005 12:55 PM
tenkhead
Nov 17, 2005 09:59 AM
tenkhead
Oct 27, 2005 08:53 AM
xephx
Mar 1, 2004 10:19 PM
cgnismo240
Jul 22, 2003 02:35 AM
