swap and stall
Old Oct 25, 2005 | 12:24 AM
tenkhead's Avatar
Question swap and stall
Ok, so here is the problem, or situation rather.
I have a 89 240 hatchback. I just put in a SR20DET with tranny, ECU, a new comp. clutch, new GReddy intercooler and blowoff valve.
Whenever I start it up, it hums just fine, however once I drive around for a bit it seems to try and stall out whenever i slow down for a red light or a stop sign the RPM's drop too low and it trys to stall out.
I've been asking around and the general idea is that my blow off valve needs to be tweaked up a bit. Also, it seems to me that perhaps my blow off valve is pushing out too much air messing up my Mass Airflow Sensor.
Any advice on this? Or perhaps parts to replace? Help!
Old Oct 25, 2005 | 04:00 AM
2fast4y0u's Avatar
just check the idle... maybe adjust it so it doesnt die when you slow down
Old Oct 26, 2005 | 06:42 AM
Skiboard06's Avatar
how do you adjust idle 2fast4you? yea u prolly need to tighten down ur BOV some u sound like u r leaking boost from it venting. Maybe try cleaning out ur ICV and ICV piping
Old Oct 27, 2005 | 08:53 AM
bullet23's Avatar
To adjust the idle as far as i know you just tighten the idle screw, which is on or near the throttle i believe. You can pick up a chilton book for like $15 and it tells you how to do that and alot more. Just a thought
tenkhead
Nov 17, 2005 09:59 AM
xephx
Mar 1, 2004 10:19 PM
Hella 240
Jan 28, 2004 04:51 PM
cgnismo240
Jul 22, 2003 02:35 AM
