Hotshot Header Questions
Old Apr 11, 2003 | 09:56 PM
jtsarnak's Avatar
For those who have bought these headers for you KA24DE, did you have a Check Engine Light issue like their website talks about? I'd like to hear from everyone, but specifically if you have a '95 and up.
Old Apr 16, 2003 | 10:12 PM
SoloDrift1's Avatar
yup yup i started out with an evap code then after i put the headers on i had like 3 codes.
Old Apr 20, 2003 | 07:05 PM
ANOTHER_240sx's Avatar
why dose the check engine light come on?
Old Apr 20, 2003 | 09:44 PM
SoloDrift1's Avatar
its sumthin with the O2 sensors. they suggest relocating the second sensor behind the resesonator because with their headers the o2 sensor reads incorrectly.
Old Apr 21, 2003 | 08:14 AM
jtsarnak's Avatar
Supposedly the '95+ have 2 O2 sensors, one before the cat and one after. Since the headers replace where the stock cat goes, they have a fitting on the headers for the 1st sensor. They recommend adding a high-flow cat and placing another fitting after the cat for the 2nd sensor after the cat. This will correct the problem, but I was wondering if it was even a problem.
Old Apr 30, 2003 | 10:57 PM
SoloDrift1's Avatar
yeah i think it is. evap is for some vacum leak i have. the second code was an egr code i believe (could be the sensor on the side of the headers). and the third was sum BS code that nissan put so that i would run back to them so that they can tell me they hafta charge me 2 million dollars to get me a new gas tank cap.
but if you're not throwing any code then you should be straight. i am and need to get it fixed before emissions testing.
Old May 1, 2003 | 12:49 AM
Sizzzoooo's Avatar
Sil, screw the emisions testing.
Get your sister to register your car out in Johnson City. Its only $25..and NO EMISSIONS TESTS!
That **** has saved my ***, there is no way my car would pass in Nashville.
Old May 1, 2003 | 07:51 PM
well if i were going ot put a testpipe on my car would it do the same?
Justin.b
Apr 26, 2006 05:10 PM
Wildcard
Feb 15, 2005 04:28 PM
erebunialtima
Jun 1, 2004 07:15 PM
240sx'in
Feb 25, 2004 12:32 AM
240sx'in
Jan 29, 2004 06:18 AM
