how to replace alternator?
Old Dec 17, 2006 | 01:55 AM
aurora61's Avatar
ive searched, but i havent really found good info on how to replace an alternator on the ka24e. Im mostly concerned about how to loosen/tighten the belts in order to remove/install the alternator from the engine bay. I also want to know whether i should remove it from the top or bottom of the car.
If anyone could give me step by step directions, that would be great.
Old Dec 17, 2006 | 04:59 PM
first if you have the mechanical fan still on the water pump i will make it easyer to work if you remove it. first remove the p/s belt then the ant. the p/s belt has an idler pully loosen that and the belt come off. the alt. has a long bolt that secures it to the engine, but first loosen the tension bolt then the bolt it pivets on.
all you need is four wrenches; 10mm, 12mm, and two 14mm. if you do remove the fan it's real easy to work from the top of the car until you need to remove the piveting bolt. there's not much to it.
Old Dec 18, 2006 | 09:26 AM
buyMEbeerPLEASE's Avatar
disconnect your battery terminals before anything haha. and make sure your belt is tensioned good when the new one is on.
Old Dec 21, 2006 | 10:10 AM
i understand why the battery needs to be disconected for alot of prosesures but honestly i've never bothered to do it and never had a problem. with that said i don't want to sound like i'm encurageing others to be neglagent. so yes defanetly disconect the terminals. but because i never do i failed to mention that step.
Old Dec 21, 2006 | 10:53 AM
yeah, i've neglected to do it too just some common sense advice so you don't shock the ***** out of yourself. i've heard some stories
Old Dec 24, 2006 | 01:28 PM
aurora61's Avatar
I have a couple of questions.
I already removed the shroud and the fan. But im not sure which pulley is the idler pulley u mentioned (i labeled the pullies in the pic below)...and could you tell me how to loosen it? Do i just loosening the bolt in the center of the pulley?
Old Dec 24, 2006 | 02:05 PM
pulley #1 you first loosen the nut on the face of the pully then the bolt. the bolt is what tightens and loosens the belt. the nut just holds it in place. both are 12mm i belive could be 14mm i don't remember but i dosen't realy matter.
pulley #2 remains in place, aswell as #4 and #5 don't worry about them at all.
for pulley #3 first loosen the bolt on the face of the alt. then the longer more noticable bolt, both are 12mm. at this point you might be able to pivet the alt back and forward. there is a 14mm bolt under is that holds it in place. take that one off and the alt. will come off completly. then just remove the wires and your ready to instal the new one.
to put everything back together the only thing you realy need to do is make sure you place the alt. belt on first then the p/s. you don't even need to tighten enything untill you got everything in place.
this is a bit of a long read but realy simple to do. also you didn't have to remove the fan and shroud but now you have more room to work with.
Old Jan 1, 2007 | 06:33 AM
positron's Avatar
My car has no fan shroud so I was able to remove the alternator and take it out from the top. It was easy.
Old Jan 2, 2007 | 03:09 PM
aurora61's Avatar
thanks alot guys...i got it
Old Jan 2, 2007 | 03:36 PM
Darkvillin's Avatar
nice work to all that helped. that was some good, old fashioned, forum team work. i likey.
Old Jan 2, 2007 | 05:56 PM
yah, that's why i joined to learn and help others in any way i could.
240sxFan
Apr 25, 2004 07:06 PM
U_NeeKz
Apr 6, 2004 01:25 PM
95_240SXSE
Feb 17, 2004 08:48 PM
l2aine
Dec 27, 2003 04:55 PM
SlydeSHO
Sep 3, 2003 11:17 PM
