ka running like ish
welll, new thermostat, egr block off, new fuel filter, new air filter, and still runs like ish. im running out of ideas on what it could be. i havent pulled the injectors yet, because i have been too busy working to even source new ones.
try coolant temp sensor, it like 20 bucks and when my temp gauge was bouncing around that was the culprit, had a bunch of build up on it, It is right by the throttle body on my 93. Get some electrical contact clean and unplugg the connection and spray it, might help
the thermostat fixed the bouncing needle, sometimes. i mean, before it would constantly bounce, and now its just occasionally. whatever. i mean, im going 5 speed which will help, because i can now clutch instead of having it downshift every time you let off the throttle. and im going itb's fairly soon, so if it is a intake problem, then that will solve it. and be teh sex.
blyth7
May 9, 2007 12:15 AM
