KA24DE design Q's
1: Are the bearings "Select fit" ie no standard bearing set, but a series based on the size of the rod journal? Biggamehit sent me this link: http://www.amsperformance.com/store/...roducts_id=303
It seems to come with new bearings for the rods, but if it's a select fit bearing motor, how do they know what ones I need. The prof helping me with my motor said he had a student blow a honda using "standard" bearings in a select fit motor. I know its over kill for the power I want to make but, I know myself well enough to know that I will turn up the boost later on.
2. I've asked around and got no answer but can someone please identify what the hell goes on this D-shaped port on the intake manifold? The previous owner removed so much from this car that I have no clue what all is missing or what goes where......
For your second question that D shaped port is for the egr valve.
Here is why I ask. The professor told me he had a student about a year ago who rebuilt and turbo'd a honda motor. The kid bought american style "Standard Bearings" ie one size fits all but the most screwed up journals. Apparently this made the tollerances too open on one of journals and caused the motor to lose oil pressure and he destroyed the motor while he was driving down to Virginia.
I want to do this build right so I dont have to deal with pulling the engine after this time. Any advice you can offer would be great. Thanks vinnie, you and biggamehit have both been extremely helpful.
BTW what he hell is the PAIR system and is it really necissary?
You have to follow the FSM for the tolerances that are recomended by Nissan.
So your advice is get the kit and check the tolerances, even though checking tolerances is kinda part of the rebuild job andyway. I just dont want to get this kit and find out on assembly that the bearings dont work and I have to go deal with the damn Nissan dealership here.
BTW do you know if the stock motor is select fit? I couldnt find anything on the stock bearings...
This is the kit biggamehit reccomended to me: http://www.amsperformance.com/store/...roducts_id=303
RedlineGoods.com
Apr 26, 2005 06:49 AM
240SEX
Aug 18, 2003 01:55 AM
