need help with the Ka motor
Old Jul 28, 2007 | 05:54 PM
ayoitbephil's Avatar
Unhappy need help with the Ka motor
lately my motor has been acting up on me lately. when i startup the car it has a weird idle. it starts at 1.5k then drops to 1k then rises again but when i drive it gets fubky. if im slowing down to a stop the rpm drops way below the 1k, if i stop hard enough the car will just shut off. ps alot of smoke comes out the exhaust....please help!!!!!
Old Jul 28, 2007 | 11:10 PM
hmmmmm, there are others that can probably answer this better than I can, but your idle problem could be a vaccuum leak. The smoke and RPMs may not even be related.
Old Aug 8, 2007 | 01:04 PM
i found the problem with the rpm issue now i just need help in how to find where the vacuum leak is coming from
Old Aug 9, 2007 | 04:35 AM
dkdeleon's Avatar
What color is the smoke coming out of the exhaust?
Old Aug 10, 2007 | 10:14 AM
i believe the smoke is black
Old Aug 10, 2007 | 06:38 PM
dkdeleon's Avatar
If its black smoke you are running rich (fuel).
Old Aug 10, 2007 | 07:53 PM
really? when i was running rich not much smoke came out of my exhaust more gas came out when i stepped on it lol!
Old Aug 10, 2007 | 08:05 PM
there are levels of "rich". some extra gas flow is not bad but more gas than can be ignited will produce smoke and poor performance.
Old Aug 11, 2007 | 09:14 AM
sometimes when im driving say im in first gear below 3k the car feels sluggish then after 3k the car some how have a boost of power and with the fule issue what should i do to fix that problem.
Old Aug 12, 2007 | 06:52 PM
khon_sama's Avatar
did u use some kinda octane booster? if u did....take it out or idle ur engine till the gas tank is empty .....next buy new fuel filter....then fill new gas....whatever u want 87.....bla bla.....it might help..........
Old Aug 12, 2007 | 06:58 PM
jdmflavor510's Avatar
http://www.alldata.com/service_provi.../20000713.html
this website explains a solution for the rough idle for sohc.
Old Aug 13, 2007 | 09:18 AM
i didnt use any kind of octane booster or nothing i was thinking of changing out the fuel filter.. or is it the gas im using for the car been using premium ever since i got the car..ps its a dohc
Old Aug 13, 2007 | 10:05 AM
sonicbob82's Avatar
Check your spark plugs and wires. If one of your spark plugs is not firing properly it will cause heavy smoke because it is not burning it all. Also, hold a paper towel to your tail pipe and see if anything wet is coming out. Is your antifreeze level dropping at all or looks like it is getting dirty or contaminated? If it is, then you have a head gasket leak.
Old Aug 31, 2007 | 09:10 PM
khon_sama's Avatar
i have the idle issue too....it's gone now...but it's weird when i drive it...run at 20 mph the engine acted like no fuel in the tank....like this ---run---engine off---run---engine off---run---engine off-------////i don't have the problem when it goes to 3000 RPM....every time i have to do that when i drive it.....
barcode
Aug 1, 2006 04:24 PM
Jovan
May 30, 2006 03:58 PM
slideo12
Oct 19, 2005 06:29 PM
nissan101
Aug 8, 2005 06:30 PM
goober240sx
Apr 19, 2004 10:31 AM
