no power after changing battery terminals
Old Jul 9, 2005 | 09:26 PM
singular_chaos's Avatar
I changed the battery terminals and everything was fine, headlights and all.. but once i tried to start up the engine all the power got cut off.. I still have the accessory power but if i turn the key to the ON position all the power is off... and can't even turn the headlights on anymore..the dashboard lights are on sometimes but really dim... any idea on what happened?
Old Jul 9, 2005 | 10:16 PM
LA_phantom_240's Avatar
make sure that all your connections are tight.
Old Jul 9, 2005 | 10:56 PM
i checked the connections.. it's fine. the headlights worked before I tried to start the engine.. now it doesn't work
Old Jul 9, 2005 | 11:11 PM
maybe you shorted something or blew a fuse.
Old Jul 10, 2005 | 02:34 AM
tryiian's Avatar
sounds like what happens when you don`t have the clutch in all the way...
not much help but, i`ve had friends with a clutch wire that was faulty or shredded who couldn`t start their cars.
Old Jul 10, 2005 | 06:26 AM
it's an automatic 8-o...
radio, wipers, interior light works..
exterior lights don't work.. horn doesn't work.. dash lights are out or dim... will not crank X-(
Old Jul 10, 2005 | 01:10 PM
dkdeleon's Avatar
you have a ground wire loose some were.
check all ground wires on the intake, on the motor and the body
ALSO THIS MITE BE A STUPID QUESTION BUT ARE YOU SURE YOU DIDNT PUT THE TERMINALS ON BACKWARDS LIKE + TO - AND - TO +. JUST ASKING??????
Old Jul 10, 2005 | 02:16 PM
BigVinnie's Avatar
Your ignition relay can be blown depending on what terminal you hooked up first.
Ground is the first to get disconected, and the last to go on the battery......
Old Jul 12, 2005 | 11:18 AM
streetfame's Avatar
if you accidentally mismatched the terminals then you might want to check your alternator fuse or fuses under the hood?
Old Jul 12, 2005 | 11:33 AM
I still say that you have a bad ground somewhere.
Old Jul 12, 2005 | 09:18 PM
95SilviaS14's Avatar
i say the same, check fuse first then start lookin for a bad ground wire
mrjchinchilla
Jul 13, 2009 02:25 PM
gunline_boss
Mar 12, 2006 10:08 AM
Purple240
Sep 29, 2005 02:07 AM
jjross82
Jun 19, 2005 12:43 PM
rb26dett
May 5, 2005 07:43 AM
