Not Turning Over
Old Jan 8, 2008 | 08:45 PM
ESmorz's Avatar
Not Turning Over
When I try to start the car.
All of the electronics light up and everything is jim dandy however the car makes no attempt to turn itself over.
Then, every once in a while it will start.
Any ideas?
Old Jan 8, 2008 | 08:51 PM
sounds like your starter is on it's way out.
you should have some one get a volt meter and place the test probes on the battery posts. when you turn the key if the volts drop to like 5v, then it's probably your battery. when it starts you should have the alt tested, most major parts stores will do it for free.
there are many more possibilities but without more info that's the best advise i can give.
Whattup32526
Nov 14, 2007 01:25 PM
wasaabi4784
Sep 4, 2006 05:39 PM
ryan15
Jan 28, 2004 10:59 AM
ixcocoyxi
Sep 12, 2003 11:42 AM
Monkey Boy
Sep 8, 2003 08:11 PM
