Ok so heres my problem...
The problem:
My digital speedo/hud doesnt work and dash lights dont work.
What ive done so far:
Ive checked every fuse and they are all good.
Ive replaced the dash cluster itself with a "working" one.
Ive checked the harness going into the cluster - everything good.
The solution:
I have no clue.
I dont know what else to try. All the gauges work, its just the speedo and the hud display and all the dash lights (when i turn on the headlights) wont work.
Anyone have any more suggestions?
P.S.- My sr20det is comming in in about a week or so, is this worth fixing since it is a sohc cluster?
The solution:
I have no clue.
as far as your dash lights it might be your dimmes switch. disconect the switch from the harnes, i think it has four wires i don' t remember. find the live wire, what you'll need to do i basicly use a jumper wire to conect the live wire and the cash lights.
i would recoment you use a 5amp fues as you jumper wire.
also since i don't remember the correct wires that you need to conect you might need to have more than on fuse handy.
if this works you can just rig the fuse and wires and leave them there. the same thing happen to me about 3 years ago and that's how i fixed the problem.
joe1masta
SR
Mar 26, 2008 05:34 AM
uvamosk
Aug 12, 2005 07:31 PM
