question on head
Old Nov 22, 2004 | 09:53 PM
ProjectMy240's Avatar
question on head
Can I remove my head without taking out the lifters,vavles and stuff? i wanna remove my head and then take out the lifters,vavles and everything else inside the head My friend told me i can't i have to take out the lifters and stuff out first. is he right?
Old Nov 22, 2004 | 10:48 PM
dkdeleon's Avatar
no. you can leave the lifters and valve in the head. all you have to take of are the cams so you can get access to the head bolts.
not to sound like a smart **** but if you didnt know this why are you taking off the head.
Old Nov 22, 2004 | 10:54 PM
no i already took my cams out, took my intake and exhuast manifold and stopped there cuz i wasn't sure about the lifters and valves. so its okay to be smart *** once in a while.
Old Nov 22, 2004 | 10:56 PM
taking off head to get a look inside the block because I think my pistons rings or bad and plus i think i have a bad connecting rod
Old Nov 22, 2004 | 11:02 PM
dkdeleon's Avatar
why do you think its abad connecting rod? is it nocking?
and did you mark your cams to your chain with #1 at tdc
Old Nov 22, 2004 | 11:07 PM
yes i mark everything at tdc and i think its a connecting rod cuz i been driving for months with it knock and my car had no power, and now it got really bad to the point where the car doesn't even idle anymore
Old Nov 22, 2004 | 11:16 PM
dkdeleon's Avatar
if you drove it after it started knocking you are going to need a new short block or change out the crank. i would go with the shot block. hope this help and sorry about the jacked up motor hope you get it fixed
Old Nov 22, 2004 | 11:22 PM
thanks man well i just won an engine off ebay for 120 dollars shipping was 100 bucks. so not bad, engine had 100k miles only thing it needed was a head gasket.
Old Nov 22, 2004 | 11:27 PM
dkdeleon's Avatar
damn the luck!!!!! kick ****
Old Nov 22, 2004 | 11:30 PM
yeah so the engine i'm gonna be getting i want to rebuilt it for performance and just to push 200 between 300HP without turbo then i want to turbo it over the summer
70Challenger
Jun 25, 2006 02:28 PM
revolt-rise
Aug 16, 2005 08:43 PM
WESIDA
Jun 20, 2005 05:26 PM
izzen
Jun 18, 2004 06:16 PM
79280
Aug 26, 2003 09:03 PM
