Removed mechanical
Removed mechanical
I took out my mechanical fan the other day. I wired my A/C fan to come on with a switch to test thing out. Ran the vehicle(unisured at the moment) in my driveway for about 15 minutes. With the fan on it ran almost at the exact same temp as before but a 1/32 of an inch higher on the gauge.
I never drove it on the roads yet. Is it possible to get away with just using hte A/C fan? assuming i'm not adding extra load / heat by turning on the A/C?
THanks TJ
THanks TJ
my car ran forever with only the ac fan mod you are talking about... i installed an altima ac fan and it never over heated... i have yet to drive it in the heat this year since the motor has been down forever... but i had no problems when i was running it...
Possibly a valid point, I don't think my temp gauge moves more than 1mm ever after its warmed up, it sits usually 2 notches up from the bottom. I've never seen it move to the half way point, let alone get hot. I was thinking of replacing the engine coolant temp sensor just for the hell of it, seeing if it had any effect whatsoever. I wish it was more accurate.
What are the ka's supposed to run @ temp wise?
And whats a decent aftermarket temp guage?
