?'s on removal of the clutch fan
Old Mar 30, 2004 | 09:28 PM
sleighty's Avatar
what is the clutch fan for? and what are the advantages of removing it? I am wanting to do the dual 10in fan swap but i don't know exactly what the clutch fan does... or if it is there to make alot of noise...lol.. or just make the bay look fuller....
Old Mar 31, 2004 | 12:18 AM
s14.5boy's Avatar
it cools the engine, you can take it off and not experience the lose of power you do when it engages because the pully that spins it wont have to work as hard.
Old Mar 31, 2004 | 01:19 AM
Moved to NA, post in the right area!
You can remove it and there isnt much of a advantage to it.
Old Mar 31, 2004 | 09:51 AM
drnovascotia's Avatar
I removed mine, rev's a little happier now. Saves up some room, looks cleaner, and i put 2 12" fans on the radiator instead. I'm in NH so I won't have to worry about 100+ temperature, so it shouldn't be a problem. Cheap and good mod.
Dr.
Old Mar 31, 2004 | 07:46 PM
ZenkiSE's Avatar
From: You know the dirty south...I live in the clean spot
i did it as well take a look ay my pics and there is a pic of the engine bay. Makes it look alot cleaner plus it helps performance by a hair.
onlyonekaoe
May 2, 2011 08:00 AM
Scuderia
Oct 21, 2007 03:05 PM
bucket240
Jul 31, 2007 11:06 AM
iNmotioN
Apr 25, 2006 10:48 AM
Chiefgmsr
Feb 1, 2006 12:49 AM
