s14 ka block question!
Old Feb 25, 2010 | 10:09 PM
bigDside's Avatar
hey guys nubie here frm texas, well a friend frm around here is giving me a ka block frm an s14 bt i own an s13, my question is are the blocks the same frm 91-94 to 95-98 as in bore n stroke? if they are id really like to use it to build a ka frm the ground up! thanks!
Old Feb 25, 2010 | 10:14 PM
good reading.. http://en.wikipedia.org/wiki/Nissan_KA_engine
They are all relatively the same... however the compression ratio on them are slightly different.
Check out the NA motor thread for much useful info. Big Vinnie the NA guru pokes his head in from time to time.
Old Feb 26, 2010 | 08:58 PM
SmokedZenki's Avatar
the blocks are identical as far as i have seen.. the difference is the head, cams, intake mani, and valve cover... head had different bolt pattern for the valve cover, cams on the s13 are more aggressive than the s14, s13 intake mani has the butterfly valves s14 doesn't... but the block is the same... hope this helps
-Eric
Old Mar 1, 2010 | 01:42 PM
bigDside's Avatar
thanks for the info guys!
Old Mar 2, 2010 | 07:41 AM
biggest difference is the emissions from Obd1 to Obd2 you see most of the changes in the head and intake manifold.
Old Mar 4, 2010 | 08:14 AM
bigDside's Avatar
yeah c i was plannig on just getting an s13 head n build it that way!
Old Mar 4, 2010 | 12:54 PM
my setup
98 KA ( I have owned every KA )
95 stripped intake manifold ( secondary butterflies already removed by factory )
93 obd1 electronics
Turbo
Old Mar 12, 2010 | 08:30 PM
bigDside's Avatar
how has that set up worked for you?, do you have upgraded internals?
norman_069
Aug 21, 2006 03:48 PM
revolt-rise
Dec 6, 2005 12:35 PM
Enlefo
Oct 22, 2005 11:41 PM
YangpaNemsay
Jul 20, 2004 01:35 PM
Red S13
Jun 6, 2003 05:04 PM
