safc II
Old Jun 11, 2005 | 07:27 AM
fast240's Avatar
safc II
i just got my safc 2 yesterday and tried installing it but in the middle of installing i noticed that the instructions were for a 91-94 install and i have to install it into a 90 and i know the ecus are different, could somebody help me and i tried apexis webpage for the us update but cant find it anywhere in the product documentation on adobe could someone help thanks
Old Jun 11, 2005 | 08:06 AM
2fast4y0u's Avatar
she still be the same. hook it up and just turn key on to make sure you have all the pwoer and functions
Old Jun 12, 2005 | 08:21 AM
fast240's Avatar
thanks
Old Jun 12, 2005 | 08:22 AM
BigVinnie's Avatar
NO! SOHC and DOHC ECU's are different, SOHCS can use eprom emulation due to one mother board 8 bit mapping, DOHC OBD1 and 2 use daughter boards 16 bit mapping, they have different wiring.
Go to www.zeroyon.com they have every ecu diagram that you need. Dont forget disconnect your ground to the battery wire hooking up the SAFC you could fry it.
For the 12 points on the SAFC don't run your values higher than 30% above normal, on stock mods "injectors, and fuel pump" you will shorten the life expectancy of the stock pump. You will also get bogging issues running into 40%.......
Program the values starting at 1600RPM, not 1000RPM. In an open loop it will cause idle issues............
Just a word of advice.
This is for stock KA's and SR's.
Old Jun 13, 2005 | 11:45 AM
fast240's Avatar
i tried opening it but my acrobat reader wont encrypt or something
Old Jun 13, 2005 | 12:06 PM
fast240's Avatar
i really need some help on the install there are so many wires its crazy thanks for the help remember its a sohc 1990
Old Jun 13, 2005 | 04:22 PM
BigVinnie's Avatar
Dude, download the newest acrobat reader.
Old Jun 13, 2005 | 09:51 PM
fast240's Avatar
i downloaded the newest version of adobe like 10 times and it still wont let me view it
Old Jun 14, 2005 | 07:46 AM
BigVinnie's Avatar
Download the PDF again, or reboot your computer, you need those files......
If I uploaded the file for you it wouldn't do you anygood anyways especially if you can't view it.
Old Jun 24, 2005 | 02:29 PM
nsn240's Avatar
haha Vinnie, you sound like a pro at life... anything from cars to computers, you seem to have it covered (not that downloading Adobe is a big deal, but...)
Old Jun 25, 2005 | 11:25 PM
95SilviaS14's Avatar
what exactly does the apexi safcII do for you on a none turbo pretty much stock ka?
Old Jun 26, 2005 | 08:30 AM
BigVinnie's Avatar
It advances the TTP of the ECU.
Put it in a real world situation. Lets say that you have the MAF at 4.0volts of air coming into the engine, but you lie to the ecu and it reads 3.5 or 3volts.
The engine will still be taking in the same amount of air as if it was at 4 volts, but saying that it is at 3.5 or 3 volt's it will now inject more fuel into the engine "longer length of time in the injection cycle than normal" . Increasing fuel increases the the CHP of the engine. This will also advance the rate inwhich detonation occurs. Bringing more top end power to the power band.
jramosthe1st!
Sep 9, 2007 06:02 PM
bnaley
Aug 27, 2003 09:44 AM
TurboEvo
Jun 5, 2003 11:52 AM
SiNFuL
May 28, 2003 07:25 PM
LI S13 Blacktop
Apr 7, 2003 07:33 AM
