Shake Rattle and Roll
Old May 10, 2005 | 09:55 PM
Shri222's Avatar
Exclamation Shake Rattle and Roll
I Need help
Today I started my car, and it was shaking like all hell, the whole call , i poped the hood the engine looked like it was possesd and was dancing all over my engine bay. The ruff shake gose away at higher then 1000 rpms.
I pulled all plugs, and replaced one, i turned on the car and pulled plug wires one by one, cyclinder 4, 3, 2 all cause the roughness to become better. pulled cyl 1 and there was no change. Cylinder 1's plug also smelled like gas, i replaced the plug and wires. No differnece, I pulled the wire to Cyclinder 1, and put a plug in it held it over the valve cover there was spark but to the VC, not inbetween the plug.... Someone suggested the timing chain must have sliped.
What the hell is wrong with my car. I parked it in storage cause I can't drive it like that....
Old May 10, 2005 | 11:42 PM
RPS13Freak's Avatar
That's what went on when I first got my car, but it was just the engine and the tranny mounts that needed to be replaced. Well that's what solved my shaking problem.
Old May 12, 2005 | 02:03 PM
acfalconhawk's Avatar
check your fuel injectors. when one of mine went out the vibrations were so bad that my legs felt like jello.
big302
Jul 31, 2007 05:51 AM
S13NismoStyle
Oct 13, 2006 05:46 AM
s14pope
Sep 13, 2006 09:02 AM
l2aine
Mar 20, 2004 12:49 PM
