Sputtering and wont rev over 3g's
Old Oct 25, 2006 | 10:40 PM
racedk6's Avatar
All right guys lets see if we can fix this one.
I have a 1990 240sx, it starts and idles fine most of the time. The problem is when I go to give it gas it will sputter and not want to rev. It will rev if I slightly give it gas, but it will only make it to 3,000rpm before it sounds like the fuel cuts out. If I floor it, it will bog really bad a back fire like crazy.
I replaced the MAF and the fuel filter today. I did have a crack in the rubber intake hose by the throttle but I fixed that for the time being.
All this started when I got home last night. I did bounce it off the rev limiter in first gear, then everything went to ****. I did fill up with gas earlier that night but drove like 40 mi before this happened. I already put some heet fuel additive just incase it was bad gas but the car still runs like ****.
I need to fix this problem ASAP cause it needs to be my daily driver until the summertime, when I can ride my bike.
Thanks for any helpful advice
Old Oct 26, 2006 | 05:42 PM
re037's Avatar
try a new o2 sensor
Old Oct 27, 2006 | 10:17 PM
dkdeleon's Avatar
can you hear the fuel pump when you turn the key?
sounds like fuel pump.
Old Oct 28, 2006 | 09:11 AM
racedk6's Avatar
I figured it out it was the top half of the distributer that came loose.
Old Nov 25, 2006 | 08:05 PM
i was going to say to replace the router in the distributer, but good to see you found the problem and it didn't cost much.
ReigH
May 24, 2006 07:42 AM
bottombunk
Feb 19, 2005 06:34 AM
Eviscerator
Aug 19, 2004 05:06 PM
lionel
Mar 19, 2004 05:43 PM
Major Mayhem
Jun 17, 2003 12:03 AM
