starting issue. need help asap!!
Old Jun 11, 2006 | 09:04 PM
Jovan's Avatar
Here's the problem, when i try to start my motor, it starts and revvs to 1k then dies down until it cuts off. Then when i try to start it again, it just turns over and sounds like it wants to start but it doesn't. The only way i get it to start is by pressing on the gas a little while turning the key and revv it up at 1.5k for about 5 seconds and it will stay running but then it'll idle at 1100rpm. It's been doing this for like 3 days. A buddy of mine said it might be the egr. I dunno. Please help. Thanks.
Old Jun 12, 2006 | 08:10 AM
ReigH's Avatar
post more info about your car? what engine, auto or manual, things youve replaced, etc.
Old Jun 12, 2006 | 10:40 AM
Jovan's Avatar
Ka24de, M/T, Intake, exhaust, plat +2 plugs, Mobil 1 10w-30, 44k fuel system cleaner from nissan dealer, flex-a-lite 220 fans, battery in trunk, short shifter, and my throw out bearing is going bad. Besides that, it's stock.
Old Jun 12, 2006 | 11:27 AM
ReigH's Avatar
have you had a tune up lately? distributor cap, spark plug and wires can cause this problem. is your battery new? also try cleaning your maf sensor.
Old Jun 12, 2006 | 09:48 PM
Jovan's Avatar
Okaym found the problem, the inside of my muffler was falling apart and the wool was restricting passage. So I guess the wool was causing too much back pressure and blocked it all up. Thanks though for giving help.
s1lentjames
Sep 26, 2011 11:30 PM
sav180
Mar 11, 2009 07:31 AM
onelove240
Mar 22, 2008 07:50 PM
redpotatoes
Dec 22, 2005 09:00 AM
240sx 5spd
Jul 14, 2004 10:31 PM
