Starting Problem
highly unlikely he said it turn over so probably not the starter.
i'm not convinced it's your injectors though. did you replace the head gasket yourself? and if so did you make sure the engine was at tdc and the dist in the correct place?
^yes i was extremly careful when changing the head gasket and it didnt have to be done so i took my time doing it. i also went to check the injector ground today but my multimeter is dead so i guess i'll have to wait on that for now (Edit) im pretty well positive the injectors not getting a signal is the problem because i can start it on carb cleaner,staring fluid or gas through the intake
uvamosk
Aug 12, 2005 07:31 PM
