steering wheel shakes at 60mph
Old Feb 19, 2005 | 11:22 PM
tcd's Avatar
tcd
hello
i have a 96 240sx and the steering wheel shakes at 60 to 70mph then stops shaking at 75mph+. any suggestions on what the problem is. thanks.
Old Feb 20, 2005 | 01:40 AM
KeN VeRsUs RyU's Avatar
maybe an alignment or maybe you need a wheel balance. Probably the latter. That would be the simple answer. Could be something complicated. Let's hope not.
Old Feb 20, 2005 | 05:52 AM
wikd240's Avatar
i would start with the balance of the tires...it is cheap and you can rotate em at teh same time...if that cures the problem then you are set... now if that did not cure the problem it could be time for alignment... if the problem moved from the steering wheel to your butt (meaning you can feel it in the rear of the car not the front) i would have your wheels checked... a bent wheel can make the car do all kinds of things... now i hear but i never hit a curb or anything like that... it only takes a pot hole the size of a coffee can to bend a wheel... just something to check...
Old Feb 20, 2005 | 08:21 AM
DriftOrDieTryin's Avatar
my car dose the same thing
its the traction control rod bushings there dry rotted to nothing
im ordering new bushings from PDM racing soon there about 50 bucks for two bushings
Old Feb 20, 2005 | 02:14 PM
baka-mono's Avatar
My car does the same thing. Ive ran my wheels on the balancer and all four had bent or warped rims. It was so messed up that an instructor and I spent 30 mins trying to balance the darn thing and gave up. Im also missing one lug nut each on three of my wheels. That prolly has something to do with it too.
Old Feb 20, 2005 | 07:25 PM
tcd's Avatar
tcd
thanks for the suggestions. ill try them out.
Old Feb 21, 2005 | 08:05 PM
BigVinnie's Avatar
Change out your bushings to propellien, get a new alighnment and balance that will fix your proplem. If you don't replace the bushings you will be making alighnments more often....
Also check power steering pump and reservoir, you could be getting air in the pump.
Old Feb 21, 2005 | 08:22 PM
DStinnett's Avatar
Check you tie rod ends, mine was doin the same thing
Island180sx
Sep 28, 2008 12:26 PM
Bryan
Jan 24, 2006 11:54 AM
Collin
Sep 20, 2005 05:47 PM
go S13
Sep 20, 2004 06:55 PM
xephx
Mar 1, 2004 10:19 PM
