Strange fluid surrounding spark plug #2
Old Sep 17, 2004 | 10:15 AM
S14Dude's Avatar
Anyone have this problem? I believe it is oil. But im not 100% sure. Anyone know why this is happening? Leaky valve cover gasket? How much is a new gasket? Im going to take off my valve cover today to remove the timing chain guide and i would like to fix this problem, help is GREATLY appreciated.
Old Sep 20, 2004 | 08:34 AM
SnickersGirl's Avatar
um..i found something called oil fouling. it's a wet, oily deposit on the electrodes. it could be worn or broken piston rings and defective or missing valve stem seals
Old Sep 20, 2004 | 09:54 AM
S14Dude's Avatar
hrm.....so in other words....its really bad.
Old Sep 20, 2004 | 01:25 PM
They recommend you use a hotter plug...but it doesnt solve the problem...I tried searching for an answer, I couldnt find it..Maybe someone can help?
Old Sep 23, 2004 | 08:09 AM
Joel SX's Avatar
It can either be The Valve cover seal, that goes arround the sparkplug. Sometimes its starts to get messt up and start leaking oil, but not in gallons, only a very small steam of it, This makes only the finest oil go trough, so it looks like something else. It used to hapend to a 95' isuzu Rodeo i had. Just try to use one of those sealants treatments they sell, or if ur taking the gasket out, by another one its like 9 to 13 bucks. It can also be that the spark plug is not tight enough, but sparkplugs are not meant to be super tightened. so be carufull, make shure they have that small washer on them, or make a seal yourself with some gasket material( not recomended) If it doesn't work, then take it to a mecaninc!.
Old Sep 23, 2004 | 08:34 AM
I think they cost around $100 if you want a mechanic to fix the problem
Old Sep 23, 2004 | 11:00 AM
S14Dude's Avatar
daym....
USMCDrifter
Dec 6, 2007 07:49 AM
bw54867
Mar 18, 2005 06:47 PM
tnd240
May 1, 2003 08:20 PM
Turboed240
Mar 19, 2003 03:04 PM
DCTperformance
Feb 4, 2003 11:39 AM
