trouble with cooling system
ok, semi-long story.
I was driving on the highway and noticed my car started to over heat, so i stopped off. i decided to turn back to home, and made it there after letting the car cool off for a bit. After some checking, i noticed the water pump was leaking pretty badly, so i replaced it. no more leak. I still overheated after i bled the system. Today i replaced my thermostat, i finally heard the radiator fan kick on after a long time of not (relief). When i was attempting to bleed it today, there was ALOT of bubbles and i tried both the radiator cap method and the bleeder valve. i figured even if i got most of the air out id be ok. Well i dont think its over heating any more, but there is still air in the system i think. The coolant tank was bubbling when i pulled into my driveway, it didn't feel very hot, just had alot of bubbles from the radiator.
i know what youre thinking...headgasket.
the thing is though, the car doesnt display any signs of a blown head gasket other than not being able to bleed properly. when i drained the coolant today i didnt see any oil in the coolant, theres no smoke coming from the exhaust, the temperature gauge isnt SHOWING that im overheating (keep in mind i replaced the thermostat today). so what do u guys think?
isnt there a way to check for coolant in the oil by putting the dip stick on something hot to see if it boils or something like that?
thanks
thanks
nissans13
Aug 23, 2006 02:54 PM
SilviaSativa
Mar 14, 2004 01:14 AM
