what size?
what size?
What size is the engine mount mounting bolt so i know which size socket to grab first before i go under the car to replace my mount... my guess its a 13mm??? but someone correct me please.
guys i have a problem!!! my engine mount mouting bolt is stripped.. i went under the car.. with a long extesion and the 14mm.. and yeah its stripped.. its my broken mount.. what do i do now?
is it the bolt holding the mount to the frame? or one of the bolts holding the bolts holding the engine to the mount?
If its the bolt holding the mount.. just undo the bolts holding the engine to the mount... then once the engine is out, you can figure it out.. drill it, grind it, whatever you need to..
if the mount is already broke then once the motor is out of the way get in there with a an angle grinder and cut the mount just above frame in that silver area. bolt should fall right out after that. a hack saw could be substituted here but that would take just a little longer.
Sizzzoooo
Mar 12, 2002 03:47 PM
