what steps to turn over a rebuilt engine
Old Oct 18, 2006 | 07:47 PM
Oriaj24's Avatar
Question what steps to turn over a rebuilt engine
I built a ka24de with all new parts. i plug up everything and went to turn the engine over and it turned on but it dropped the rpms to 500 and started to shake. i was thinking if there is steps to start a new engine like maybe having it at top dead centeer or reset the ecu. i can really use someones help if they been through this.:spin:
Old Oct 18, 2006 | 08:08 PM
tehott240's Avatar
before u started it did u prime the engine before starting? and r u shure timing is right?
Old Oct 18, 2006 | 08:25 PM
the crank pulley shoudl have been set to 0 degrees while making sure the the #1 piston is at TDC. on tope of that the lower chain should have been mathedup with all of the proper links as well as the upper chain with the correct maks on th cam gears. the lobes of the cams hsould have been facing outward and the crank should have been turned prior to starting the car to ensure that there is no valvetrain problems (ie valves bending)...sounds like your timing is off whichis causing your low idle/shacing/ and probably ****ty throttle response..
Old Oct 19, 2006 | 04:40 PM
Oriaj24's Avatar
yea i think i did the timing right on it cause it was not that hard with matching the marks. i actually did it three times to because i built the engine and took it apart to add more parts. should i put the piston at tdc each time i try to turn it and do you have any idea have to use the self-diagnostic test cause i was wonder if that took help.
Old Oct 19, 2006 | 06:47 PM
LA_phantom_240's Avatar
uh no.. check our electrical timing and such as well... and make sure you prime the fuel pump 3 or 4 times before starting
Old Oct 20, 2006 | 08:07 AM
dkdeleon's Avatar
Re: what steps to turn over a rebuilt engine
check to see if all your injectors are getting pulse, I had the same problem with the shaking and rpms being low and it was #4 injecter, switched it out and bammm purrrrrr.
Old Oct 20, 2006 | 10:21 AM
Oriaj24's Avatar
i found out what happen. i took out the spark plugs and inside the cylinders it s full with oil. so i ask the machine shop guys who rebuilt the head and they said that the piston rings may not be seated so its not pulling dowh the oil. so i m throwing in the towel. if you need parts i have over 150 new parts and the whole car too.
Old Oct 20, 2006 | 11:32 AM
Alteus's Avatar
Wow dude that really sucks. What kind of parts are you selling? Thinking about rebuilding my motor in the future since it's got 153k on it.
Old Oct 20, 2006 | 04:54 PM
Giving up again Jairo?
Old Oct 20, 2006 | 05:15 PM
Oriaj24's Avatar
hey i tried but yea i have lots of parts that i bought mostly at my work because of the huge discount. i will list them all in the parts for sell section.
s14smiles
Aug 18, 2007 07:48 AM
racesynergy
Apr 16, 2006 07:01 PM
Chillin240
Oct 28, 2005 09:17 AM
wishicoulddrift
Oct 1, 2004 01:52 PM
leiferik1
Mar 30, 2003 10:15 AM
