What is wrong with this car?!!!
Old Feb 15, 2005 | 01:18 PM
coptic's Avatar
I just got my 240 and the previous owner added an alarm and sound system, I have an 89 coupe (non hud) and the engine turn over when you turn the key, but there is no power going to the spark plug wires. I am stumped and cannot figure out what the problem is. I looked a the fuse box in the footwell of the drivers side nad found that there are no wires or fuse going to the fuse on the lower lefthand side, named
" Electronics (ig)"
the car has a soch ka
Could this be my problem? I have no idea like i SAID, BUT YOU GUYS ON THE FORUM ARE THE MOST KNOWLEGABLE BUNCH OF NISSAN TUNERS OUT THERE SO IM SURE THAT YOUVE GOT AN ANSWER. Just a side question the wires that come off of the white box on the back of the ignition module, where are they supposed to be connected if they are at all?
thanks soo much in advance for your help
Please reply to Markessak@gmail.com
Old Feb 15, 2005 | 01:44 PM
ProjectMy240's Avatar
put a new fuse in there for ur electronics and check/replace ur plug wires is what i would do
Old Feb 15, 2005 | 02:09 PM
coptic's Avatar
wHAT WIRES ACTUALLY GO TO THE IGNITION FUSE? I KNOW ITS A STUPID QUESTION...
Old Feb 15, 2005 | 02:22 PM
not sure on the top of my head i'll have to maybe go out to my car and look for you or maybe someone will post and let u know
Old Feb 16, 2005 | 06:12 PM
s13_peacekeeper's Avatar
did you replace your distributor, dis. cap, wires and spark plugs. thats what i would do.
Old Feb 17, 2005 | 06:40 AM
coptic's Avatar
the distributor may need to be replaced...i was thinking its either the fuse for the ignition ( the lack thereof actually) or the ignitor coil or a combination of the two...but I'm an idiot
Old Feb 17, 2005 | 07:25 PM
struck1's Avatar
first i would disconnect the yellow wire--or maybe it is the red...it is the one in the alarm harmess with the fuse--just take the fuse out of the holder on the wires coming from the alarm box to eliminate the most obvious...disable the alarm then start checking ignition---coil--distributor-- wires...does the car just spin or does it try to start and just wont????
lanb135
Oct 24, 2006 06:35 AM
ehxtahcee
Nov 17, 2004 08:36 AM
duckman240sx
Oct 11, 2003 03:38 PM
battlestylespl
Feb 24, 2002 10:59 PM
