Where to buy a FULL pulley kit
Old Apr 21, 2009 | 03:56 PM
  #31
hatrick6's Avatar
Originally Posted by 240-kid
The Almn pulley doesnt Dampen the Harmonics that the engine makes
Read here...
it says i have to log in to view the page, mind copy and pasting for me, pretty please???
Old Apr 21, 2009 | 06:25 PM
  #32
240-kid's Avatar
Would be glad too
http://www.dinancars.com/bmw/technia...armonic-damper
Old Apr 21, 2009 | 06:45 PM
  #33
as far as i know there is only one company that makes dampening pullies for the KA and its ATi and they arnt cheap $500-$1500 forgot how much exactly.
i just run the stock crank pully with everything else changed but nothing is underdrive and i have no belt slap because i use the stock crank pully.
imo i didnt feel a huge difference at all i mean by itself its not much but with other mods it adds up. i got my light weight flywheel after and that was a HUGE difference.
i say just leave the crank pully alone just replace the rest
Old Apr 21, 2009 | 07:11 PM
  #34
you're forgetting something adam, you have a sr so obviously it would respond better than a ka. if fact i don't believe i've ever seen a dyno of any na application. even then it was like 8hp with all the pulleys at around 7500rpms. don't quote me on that last part because it's been a while since i've bothered looking into. either way let us know how it goes.
Old Apr 21, 2009 | 07:38 PM
  #35
240-kid's Avatar
Thats a dyno ImportTuner did back when Unorthodox was still making the KA Pulley Sets, this was done on an 96' S14
Peak numbers were:
130whp -> 138whp
142wtrq -> 150wtrq
Still not worth the engine damage in the end from the Crank Pulley, just run the Underdrive set and be done w/ it...
Old Apr 21, 2009 | 08:10 PM
  #36
hatrick6's Avatar
Peak numbers were:
130whp -> 138whp
142wtrq -> 150wtrq
would the underdrive set (everything but he crank pulley) actually free up any hp at all? also, i'm gona play devil's advocate her, can anyone show me any other instances where people say how bad the underdrive crank pulley is?
Old Apr 21, 2009 | 08:45 PM
  #37
but why why why why go underdrive? just go lightweight. with underdrive the actual pully is smaller so like vinny said your powersteering will be weaker AND your alternator wont be charging properly at idle.
just buy a light weight pullies not underdrive
Old Apr 21, 2009 | 09:01 PM
  #38
BigVinnie's Avatar
The devil also plays on the ignorance of people. So if you chose to think that an under drive crank pulley is the way to go, don't go crying to s-chassis.com when you wonder why your cylinder compression is low, and your engine spun a bearing as well after 6 months.
Old Apr 21, 2009 | 09:32 PM
  #39
240-kid's Avatar
the Pulley's are actually bigger then stock causing the underdrive effect
And I highly doubt you'll see gains w/ LW pulley's considering pulleys are light to begin w/ IMO
Old Apr 21, 2009 | 10:03 PM
  #40
lol well w/e but mine were considerably lighter. the stock waterpump pully was heavier then all 3 aluminum pullies put together
Old Apr 21, 2009 | 10:33 PM
  #41
BigVinnie's Avatar
Just machine the stock pulleys. Extrude and remove metal, but make sure to keep it balanced. I'm actually looking to find a way to drill holes in the stock pulleys to make them lighter.
Old Apr 21, 2009 | 10:56 PM
  #42
there shouldn't be a problem with balancing them since the diameter is so small. also if you take a look at the p/s pulley in my sig you'll notice that the holes are considerably larger. i didn't do it to reduce weight but rather so it would look different. all it takes is a drill press and a carbide bit like these.
Old Apr 22, 2009 | 06:55 PM
  #43
hatrick6's Avatar
ya i was thinking about that, but after looking around i can't seem to find just a lightweight crank pulley, they are all underdrive. and even if you could find one how do you know it will be balanced light the stock pulley?
hmm, an interesting idea, i do have a drill press and could pick up a carbide bit, but how do i check if the pulley is still balanced after i drill it?
Old Apr 22, 2009 | 09:44 PM
  #44
BigVinnie's Avatar
Best thing you can do to keep it close to balanced is to measure the diameter of the pulley. Find a mathematical equation to partition the pulley into sections and remove the metal according to the pattern or arrangement that you would remove the metal. Make a couple of template moch ups and see what you can come up with. Like Jramos said, you shouldn't be to concerned with balancing since the rotating mass is so small.
Old Apr 23, 2009 | 03:51 PM
  #45
hatrick6's Avatar
ya thats what i figured, was just just wondering if there was some kind of tool i could test the balance with.
would this be safe to do with the crank pulley also? or just the accessory pulleys?
