My jeep wants to shut off when i come to a stop...help PLEASE!!!
Old Dec 18, 2003 | 05:13 PM
NOS_is_4_cheat's Avatar
Angry My jeep wants to shut off when i come to a stop...help PLEASE!!!
ok...i just replaced alot of parts in my jeep to make it start...long story and i dont have that much time...
well...when i come close to coming to a complete stop my jeep wants to cut off...so i have to ride the brakes and it gets very annoying...especially when im in a drive through and it almost cuts off and i have to press the gas and it will kind jump forward...any ways...
when im like in park it will idle fine but when its in gear...put put put blaaaa...it cuts off...and when im idling while im in gear IF it dont cut off...its turning like only 500rpm....really low...so...
does any one know how to idle up a fuel injected vehicle...its very easy with a carberator...but i know nothing about fuel injected systems....
PLEASE PLEASE HELP ME
thank you so much
Old Dec 19, 2003 | 05:04 PM
drnovascotia's Avatar
Moved To off Topic because this is for sure not about a 240sx. Have you checked for Jeep forums? Might be more resourceful.
Dr.
Old Dec 19, 2003 | 10:57 PM
s14.5boy's Avatar
You can adjust your throttle cable, or check/replace the Idle Air Control valve.
Old Dec 20, 2003 | 03:18 AM
Neferdite's Avatar
I think you answered your own question when you asked if anyone knows how to idol up a FUEL INJECTED vehicle... Check the fuel injector.
Old Dec 20, 2003 | 07:08 PM
s14.5boy...if i adjust my throttke cable...will it flood my jeep when its not turned on...
neferdite...wont work...thanks for the help anyway guys...if anymore people have any more suggestions...please post them
Old Dec 26, 2003 | 10:07 PM
areitu's Avatar
Check the air filter.
Old Dec 29, 2003 | 03:09 PM
irax's Avatar
no.. i had this problem befor, when i installed an aftermarket airfilter... it turned out i accidently unpluged a vacume hose... you should check out all your hoses make sure there isnt any leaks cracks broken seals, or even if they are connected.
Old Dec 30, 2003 | 05:48 AM
funny thing you say that because i saw that i didnt plug mine in at the last second...and replacing the air filter and oil filter is already done.
yutyut
Jul 16, 2008 05:49 AM
chondamx
Jun 3, 2007 06:28 PM
Cynister240
Dec 5, 2006 10:17 AM
Ghettostamps
Sep 12, 2005 12:29 AM
kang128
Nov 21, 2004 04:35 PM
