gauge lights
Old Feb 8, 2010 | 10:05 AM
B2A4IONsx's Avatar
gauge lights
okay so i have said in other post i have recently purchases a 90 240sx.
it had a hand full of issue but one of them that has be stumped.
the speedo and tach has no light.
but the clock does light up.
when i turn the switch to turn on the head lights, they turn on but i get no gauge lights.
i have went though and replaced all the fuses.
i have not replaced the bulbs yet, im going to swap to the Leds once i determine the issue.
The gas light and the other lights for battery do work though.
i am open for all suggestions!
Old Feb 8, 2010 | 11:05 AM
Jaescrub's Avatar
mine did this along with with the instrument panel ended up i needed to ground out 1 wire that was not used when i put an aftermaket headunit in you just have to ground out the red wire with yellow strips on it but when you do this the dimmer will not work any more.
fanmanflex
Feb 27, 2008 01:05 PM
topsecretgold
Aug 4, 2005 10:31 PM
240sxSleeper
May 24, 2005 12:30 PM
240sx420
Jan 21, 2005 06:58 PM
JonBrekke082885
May 17, 2004 07:43 PM
