remote starter?
Old Oct 2, 2004 | 05:58 PM
240sx 5spd's Avatar
remote starter?
does anyone know of any remote starter kits i could install on my 92 nissan 240sx? and how hard of a job is it? cuz winter is coming and i'm too lazy to sit in the car while its warming up cuz i'll freeze my butt off. haha
Old Oct 8, 2004 | 08:46 PM
gazelle's Avatar
hmn, check out viper car alarms, tey do remote starting, not sre on the difficult, justmae sure you usethe ebrake and keep your car in neutral if you have a stick r it will drive away... if you go to a car audio place the can do it, lemme know cause im wanting to do one as well.
Old Oct 8, 2004 | 11:00 PM
actually if your car is manual and you leave it in gear with a remote start, the car would just stall
Old Oct 10, 2004 | 10:33 AM
LaDyInRed's Avatar
i thought remote starters couldn't work on a manual? how would u put the clutch in to make it start?
Anyway, check out the clifford matrix RS series, they're pretty sweet..
Old Oct 10, 2004 | 03:51 PM
240sx 5spd's Avatar
yes remote starters work on stick.. and how it works you have to disable the clutch pedal switch where u dont need to push in the clutch to start the car up.
Old Oct 10, 2004 | 07:23 PM
LaDyInRed's Avatar
ahh... ok i see.. but does doing that have any adverse affects on the car? sorry, i'm new to this whole remote start thing
Old Oct 10, 2004 | 10:25 PM
Nope, no negative affects at all
Old Oct 14, 2004 | 11:39 AM
miked808's Avatar
The only side effect I had was embarassment when my car started rolling.
Old Oct 30, 2004 | 04:54 PM
Ballzac19's Avatar
not to many places will install RS systems in 5-speeds at least in MD. its agianst the law.
Old Oct 30, 2004 | 11:46 PM
S14Dude's Avatar
ya. my friend has a remote start on his Spoon EK. he did it and the car started rolling at hit his boss's car. oops. be careful with remote starters. NEVER leave the car in gear unless u HAVE to. you might forget.
Old Nov 1, 2004 | 09:30 PM
Actually you're supposed to leave the car in gear when you park. Sometimes parking brakes will loosen up and your car will roll after it's aprked for a bit (brake pad retraction). That's the whole purpose of the "clutch safety switch" where the car won't start in gear (or at all) unless you're stepping on the clutch, which ensures that the engine will start without the car lunging forward or reverse. The drag of the drivetrain connected to the wheels when the car is in gear kind of eases the strain on the parking brake.
Lady, didn't we cover the whole "using a remote start with a manual" thing in your alarm post?
Old Nov 9, 2004 | 07:18 PM
2fast4y0u's Avatar
not to be a punk or anything but all that said above sounds like bull... you can certainly out a remote start on a manual. you have to get a clutch over ride for the manual. if you order one from somewhere you jsut ahve to tell them you are puttin it on a manual car. my car was automatic and now its a manual and my remote start works just as good as it did before.
Old Nov 9, 2004 | 10:44 PM
which part are you referring to as "bull"?
Old Nov 12, 2004 | 08:51 AM
2fast4y0u's Avatar
pretty much all of it...other than the part were HyJynX said no negative affects thats about the only thing that wasnt bull. like said, im not trying to be a little pun k about this but mine works great.
Old Nov 12, 2004 | 10:52 AM
TSR20's Avatar
I have the viper alarm system with remote start and turbo timer, and everything works just fine on my sr. Just don't leave it in car and make sure your parking brake is in tune. I think this topic is dead. Bottom line, remote start is fine on manual.
