SR20 aftermarket pistons
Old Nov 2, 2004 | 06:23 PM
eddawg S13's Avatar
whats up.... i want to start building my SR blacktop.. but dont know where to get pistons with a compression ratio of 7 to 1... if anybody knows please let me know... and if any body knows of a aftermarket crankshaft please let me know... thanks
Old Nov 3, 2004 | 01:13 PM
4984 5fsdskfvjdsntr4's Avatar
Banned
I believe raretrick.com has a crank. But i dont kno about those pistons, THat's a low CR. U plannin on running some really high boost?
Old Nov 3, 2004 | 10:12 PM
SHIFT_speed's Avatar
Yeah, what's the story on 7:1 ? That's pretty extreme for a street car
Old Nov 4, 2004 | 10:36 PM
eddawg S13's Avatar
yea man i wana boost high.. im going for serious power... but i keep finding pistons that r 8:0:1 and 8:5:1 nothing lower so if ne bodys see them in 7's please let me know....
Old Nov 4, 2004 | 10:52 PM
If that's truly what you want I can have several of my piston suppliers make custom pistons. But realize that's going to hurt off-boost drivability.
Old Nov 4, 2004 | 11:06 PM
eddawg S13's Avatar
how so? can u explain?
Old Nov 4, 2004 | 11:22 PM
DISCLOSURE : None of this post probably makes sense. I've been working for 15 horus straight and quite loopy.
Power is direclty effected by your compression ratio. The more compression the more power. The less compression, the less power. The benefit of lower compression is resistance to precombustion. Increased charge compression and temperature there from will cause knock. Bad. Lower compression allows that max pressure to be reached more from charge air pressure and less cylinder compression. Two major advantages of that are the fact that 1) you have a denser charge. more air. more fuel. 2) post compression(turbo) you've created heat. same when you compress with your piston. but the advantage is you can use some sort of charge cooler (intercooler/aftercooler/etc/etc) to remove portions of that heat. But back to your question, you simply will be getting less power from your charge with lower compression. Your benefit comes from your boost spectrum, but at a sacrifice. That's the reason many street turbos will run around 9:1. You get more 'off-boost' power at the sacrifice of less boost potential (with identical other parameters(octane, timing, etc), but with more overall street drivability.
Old Nov 5, 2004 | 07:38 PM
eddawg S13's Avatar
well said... lol.. no futher questions
240sxgod
Nov 17, 2003 09:51 PM
duckman240sx
Sep 8, 2003 01:02 AM
Jonas
Mar 6, 2003 08:04 PM
S13 Slide
Dec 13, 2002 02:23 PM
RNN14
Mar 1, 2002 02:32 PM
