1991 240sx how-to build thread
Old Feb 16, 2009 | 05:18 PM
  #121
Nickmerrone's Avatar
Originally Posted by 240smoke
Yeah, some of the SE models came with the VSLD. Mine of course did not. I just welded that *****!! haha.
is the VSLD bad?
fill me in man....if so i like it cause both wheels light up. hahaa
Old Feb 16, 2009 | 05:20 PM
  #122
240smoke's Avatar
No its a good thing. The open differential is what I had, you dont want the open for basically anything. It was just a cheaper option I guess. VSLD is good for drifting. Might want to change the fluid in it though.
Old Feb 16, 2009 | 05:24 PM
  #123
**** just keeps getting more complicated. hahaha.
Never knew there was diff fluid..haha
Old Feb 16, 2009 | 05:37 PM
  #124
240smoke's Avatar
Yeah, there is alot to learn. I am still learning... I have been working on 240s for about 5 years now.
Old Feb 16, 2009 | 05:40 PM
  #125
Ight well, i wanna find out where the hell this one bolt is so i can get it started... then ill hit up the oil change, plugs(there on the way!), wires...well probably start my swap after that..hopefully ill have all my ****...This project is moving ALOT faster than i thought it would...I'm pretty pumped(is that better? do i still sound like a school girl?)
Old Feb 16, 2009 | 05:41 PM
  #126
240smoke's Avatar
Not as much. HAHA. The bolt is diagonal to the other one on the other side of the starter motor.
Old Feb 16, 2009 | 05:48 PM
  #127
I know. but like i cant get to that. Diagonal is like the same area but other side right? HAHA.
Old Feb 16, 2009 | 06:01 PM
  #128
240smoke's Avatar
If you drew a straight line from the bolt through the center of the starter motor, it would be along the line on the other side.
Old Feb 16, 2009 | 06:09 PM
  #129
Can you get to it without taking the manifold off?
Old Feb 16, 2009 | 06:18 PM
  #130
240smoke's Avatar
Yes. I think I used a socket wrench. Its a really tight fit. Its easy to get to if the car is on the lift and you have a swivel socket.
Old Feb 16, 2009 | 06:19 PM
  #131
240smoke's Avatar
You dont have to take anything off. Just take off the wires for easier access. Then get a socket on it.
Old Feb 16, 2009 | 06:25 PM
  #132
For the one on the top? And yeah i may invest in a set of swivel sockets. :P I just bought all these new tools, but like i was saving for a new box..cause I got a little *** box. and need more room.. but yeah i think im gonna get swivel sockets soon, but hows it easier if its on a lift, if the bolts on top of the car?
Old Feb 16, 2009 | 06:34 PM
  #133
240smoke's Avatar
The bolt is under the manifold... can be easily be seen from underneath the car...
Old Feb 16, 2009 | 07:14 PM
  #134
I got that one off i think.... i need to get the the driverside bolt
Old Feb 16, 2009 | 07:42 PM
  #135
oh yea VLSD is very good now you dont have to spend money on that haha
ok just to make sure it is ABS when u look at the diff close to the drive shaft does it have sensor with a wire coming out of it?
would be best if you can take a pic then i can confirm if its a ABS Diff or not
