help wiring questions
Old Sep 30, 2004 | 05:33 PM
elite44's Avatar
hi before you guys tell me to do a search, i did. i searched through all of this forums, zilvia, ziptied, ally, you name it. i have spent hours^^ and nobody covered this part. i have been flamed over and over and have been asked to leave many many times. can someone help?
alright. i have a 89 240, s13 silvia. i just got the jdm headlights and corners. the headlights have been covered many times i know but no one covered the wiring for the corner light.
the jdm corner light has 2 bulbs. the stock wire only has 1, which used to be for the usdm fender side marker. the main head light usdm is already connected to the jdm headlight(direct fit) which splits into two. my problem is the corner lights. the usdm fender sidemarker directly plugs in but that leaves the attached blinker with no wire. the head light wire is taken. the usdm headlight motor wire is soon going to be used to work the fog light wire. and the 3 thrid wire on the usdm that used to go for the bumper blinkers is going to be used for jdm bumper blinkers.
what are my options for that?
is there a way i can splice 1 wire into 2 connecting wires?
it looks like the 2 connecters i need will have to be a 2 prong female adapter. went to the store but they have different volts or something like that for the different kind of 2 prong female adapter.
will the volt meter tell me which exactly to get? that is what i am guessing. i stil havent bought one yet. thanx in advance i hope all of what i said made sense. i can put up pictures too. i will do that tomorrow if that helps. sorry if this question is too newbish.
Old Nov 14, 2005 | 05:45 PM
240yoda's Avatar
im having the same problem
Old Nov 17, 2005 | 09:29 AM
it's all 12v. Just splice.
or
You mind rewording your question without mentioning anything about headlights? There's no point in talking about all that stuff if your problem concerns 1 extra bulb.
Clarke240
Sep 25, 2007 03:38 PM
MS!3
May 19, 2007 12:49 AM
boosted-alty
Feb 15, 2007 12:08 PM
HellFire
Jul 11, 2006 06:03 AM
s13_bb2.
Nov 30, 2003 01:25 AM
