a few wiring questions
I had a few questions about wiring..
-On the gray plug near the battery tray, besides attaching the blue and black wires together, do any of the wires need to be moved around as in which hole they belong in, or are they fine where they're at, just connect blue to black and put plugs together?
-Attached to that gray plug, there is a brown one. On heavythrottle, it says to match each color on the SR harness up with its corresponding wire on the KA clip, with green with yellow stripe being AC relay. On my harness, the green wire is there, but on the KA plug, which one connects to it as there is no green wire there- does anyone know which wire the green/yellow wire connects to?
s13_bb2.
Oct 25, 2003 08:16 PM
