picked up an s14,its definitely a little different, needs some stuff, check it out
k thats what i thought. hah i know its not the engine harness, i have the engine harness in my room and i just relocated the fuse one. no just kidding i know what u mean, i just wasnt sure that maybe when plugged in, it all became one system that possibly shared grounds or something dumb.
progress for this weekend, had to work fri and sat, worked on the car all day today but had to leave a few times for parts and whenever i leave i have to put everything back together since its in a parking lot. takes forever.......so i didnt get as much as i wanted to done, but i did make some progress. the fuse box wiring is almost complete, i ran out of solder when extending the drivers side wiring. i did get pics of the passenger side though.
sorting out the location of each plug
extended and labeled each one
all loomed up and running into the cabin
got the drivers side done this morning. i still have to make grounding points for both the pass side and drivers and then ground all of the wires coming from the plugs. just stopped raining so im heading back out to get as much done as possible.
using a zip tie to hold the wires is an easy way to figure out how you want everything to sit and just how much slack you want to be left out after you loom the harness
completely loomed up
done
mounted the fan thermostat relay/temp control here, i figure its not too hard to get the bumper off and its cleaner this way
fan thermo temp sensor
can hardly see it when rad is in place
fan wiring and headlight wiring that connects from one side to the other. i wasnt happy i had to run it across, but i think its pretty well hidden. once the ac condensor goes in, they will not be visible
can anyone tell me how to hook up the heater hoses?
alternator plug wires broke just when moving the plug, can anyone tell me how to de-pin it?
i need to get a 90 degree fuel fitting for the rail, can anyone tell what size this may be close to?
this coolant port coming off the IACV, can i connect it to the port on the sensor in the lower pic?
thanks guys
done
thanks guys
almost done, black wires on left are all the extended ones from the bay
engine harness is another story
got the dp to v-band adapter ( manifold will be black, i was experimenting with two colors)
anyone want to buy a 4 inch v-band clamp? i bought it then switched turbos so i have no use for it
ha thanks man. i do not plan to stop until it is done. should be running by november 1st at the latest, im hoping much sooner though. i bought a turbo xs dual stage boost controller yesterday so all i need now is the tial waste gate to get it running, assuming i can figure out this engine wiring harness. i would like to be able to get an aem wideband too before i try and get the car tuned
thanks a lot guys.
good news is i just got a garage, bad news is its 45 minutes from where i live at my parents new house which means i wont be able to even touch the car during the week, but i will be able to get much more done since i will have all of the tools i need. this and i just a tial 44mm wastegate for my birthday, so things are looking good
