engine has trouble starting from cold
Old May 16, 2007 | 06:16 AM
projectx605's Avatar
Im looking to buy an sr swapped s13 with a redtop and he says it has a "cold start issue (starts fine on warm days)" what could this be from?
Old May 16, 2007 | 05:19 PM
helllp me with this
Old May 16, 2007 | 07:31 PM
cronux's Avatar
bad tuning, haha.
Old May 16, 2007 | 07:50 PM
Dude i know your problem. YOU DOUBLE POSTED. STOP IT.
Old May 16, 2007 | 08:12 PM
Initial Daniel's Avatar
Honestly, it could be because of a vaccum leak, timing could be off, distributor, bad starter, like someone said; bad tuning--it could be any number of things. Why would you buy a motor that has problems? Did you do a compression/leak test on the motor, or do you happen to know the results? Compression test will basically tell you the overall health of the motor. You don't even need the motor in the car to be able to tell it's compression.
Let us know what you find out. Good luck.
Old May 17, 2007 | 02:35 PM
Durdan's Avatar
could be a wiring issue, too.
zeroeffect
Jun 12, 2006 08:13 AM
redpotatoes
Oct 7, 2005 11:24 AM
Little_Red_Rock
Jan 11, 2005 03:34 PM
SpdElemts
Nov 10, 2004 01:44 PM
TwiztedParallel
Oct 12, 2004 11:03 PM
