sr20 seein what you guys think of this setup
haha nah i dont think your flamming me..
i actually wrote that wrong ha... i seen on some webistes, i think enjuku racing was sellin the sr maf for more money then the z32 and i was like huh? that dont sound right
as for the fans yea there the dual 12" ones
and if i can get a used power fc ill get one cause there kinda expensive..ill prob just use the safc at first then down the road get the fc commander
i wanted to run the hks ssqv but im hearing that the new one sucks? its not as good as the old one?
The power fc, yes quite expensive, however you are able to tune the car HELLA lot better than with the safc, but if you can get a used one thats great, but I'd still rather get a new one, due to who knows what the last owner put it through!
If I rememeber correctly, if you do happen to get a power fc, make sure you get the D-Jetro Version, it IS more expensive than the regular version, but the D-Jetro, elimates the MAF, and changes it to a MAP sensor base system. PLUS if you spend a little bit more, the power fc can be used as a Boost Controller also!!!
This comes directly from optionimports.com:
Power FC D-Jetro version will eliminate the factory Mass Air Flow Sensor (MAFS), changing to a MAP sensor based system. Must purchase D-Jetro Sensor Kit.
(Kinda jacking your thread a little!!! Sorry)
As for enjuku racing, they are awesome! I order from them alot.
ALSO, if you order from FRsport.com, and if you call them, ask for Cat, she was very helpful and very nice! She let me take several minutes to look to see if I wanted anything else to replace the driveshaft shop driveshaft, and she even made a suggestion on what I could get!!!
(end of thread jacking!)
Before I forget, when you wire them fans up, them them to TWO DIFFERENT circuits, and use ONE RELAY for each fan, I nearly fried mine by wiring them together, directly from the fans to a switch, to a fuse, and to the battery!!! Its extra wiring but it well worth it!
OR
I don't know what kind of funding you have, but if you have some extra money, I suggest on getting the HKS Dual Fan Controller! Its $175.00, but IMHO its worth it, I'll be ordering mine soon as well!
but anyways, good luck with getting what your going after! keep us updated, as I am interested in what your doing also!
Aznplayer911
Dec 4, 2003 06:32 AM
