300zx brakes with 240 master cylinder
Old Mar 26, 2005 | 06:58 PM
JDMxDrift's Avatar
I plan on doing 300zx brakes on the front of my S13. I've heard some guys say that the brakes feel mushy with Z brakes all the way around when they use the 240sx Master Cylinder. Has anyone expierenced the braking with Z front brakes only and 240sx MC? Its 10 piston around vs 12 piston around. Thanks for the input.
Old Mar 26, 2005 | 09:05 PM
Levi SPL S14's Avatar
10 piston??
Z brakes are 4 piston.
I have Z brakes 30mm.
My braking is fine because I use Stainless lines.
Good luck.
Old Mar 26, 2005 | 11:43 PM
JDMxDrift's Avatar
4 piston in the front (x2)=8
single piston in the rear (x2)=2
8+2=10
Z rear brakes use 2-piston. 4+4+2+2=12
Thus, out equation equals 10 pistons vs. 12....
Do you only have Z brakes in the front?
Old Mar 27, 2005 | 01:20 AM
240-kid's Avatar
Or you can buy a new Master Cylinder
Old Mar 27, 2005 | 06:08 AM
Catharsis's Avatar
dont do it with astock 240 bmc upgrade to the z32.. also get a previoning valve
Old Mar 27, 2005 | 02:13 PM
ArticDragon's Avatar
Upgrade if you're doing all four corners. Other than that, many 240 owners with just Z32 fronts use the 240 MC.
Old Mar 27, 2005 | 08:21 PM
Catharsis's Avatar
no upgrade either way.. jsut a z32 front with no bmc upgrade leads to locked fron brakes and nothing more
Old Mar 27, 2005 | 08:56 PM
JDMxDrift's Avatar
Why would it be locking my front brakes?? Would this problem occur even with steel braided lines?
Old Mar 27, 2005 | 09:37 PM
buntavy's Avatar
I did my Z32 front and rear w/ebrake on my S14 and use stock 240SX MC. Also replace brake lines. Mine's working great.
Old Mar 28, 2005 | 08:19 AM
That only if you dotn knwo the lockling point of the brakes.
JDMx whatever I know that the front is 4 and the rear is 2, you know why?
Because I HAVE THEM!!!
If your going to have the full up grade them I suggest Z32 MC. If your only going to use the fronts only, SS line with Stock MC.
Old Mar 28, 2005 | 02:42 PM
silviadriver's Avatar
if ur gonna leave stock rears, upgrade toa new MC. i have a MC that will make the upgrade less "mushy pedal"
it is a 15/16' MC. stock 240s are 7/8 depending on the type of car
viet_nismo@hotmail.com
email me for details
Old Mar 28, 2005 | 04:21 PM
JDMxDrift's Avatar
Land_Ho. Don't get upset, you said "10 piston??". So i just wanted to clear that up for you. Man you get angry easily...
240SILV
Sep 14, 2005 02:41 PM
RedShiftZ
Apr 6, 2005 11:15 AM
Dounveeme
16
Jul 10, 2004 01:32 AM
fatallightning
Northeast
Dec 3, 2002 12:31 AM
