5 lug how to for S13
Old Feb 15, 2005 | 01:04 PM
  #61
ArticDragon's Avatar
You can redrill stock rotors.
Old Feb 15, 2005 | 02:23 PM
  #62
Levi SPL S14's Avatar
Originally posted by phreze
Ok, so front goes like this:
Attain/GTO 5 lug hub with bearing
5 lug rotor
and the rear is
300zx 5 lug hub
s13 bearing
5 lug rotor
and thats it?
Okay this is the last time.
FRONT
Attain/GTO/Peak Performance Hub (bearing's included)
5 lug rotor or Redrilled stock
Rear
NA 300ZX/S14/S15 (do NOT need to change bearing unless damaged)
If you cant understand this then please sell your car.
Thanks
Levi
Old Feb 15, 2005 | 03:18 PM
  #63
phreze's Avatar
I'm sorry that I am not as uber/leet as you about 240sx's. I have read many places and they all use different things so I was trying to figure out exactly what I needed.
I read that you needed new S13 bearings for the s14 hubs on a vendor website and was trying to figure out if they were just trying to sell a new part for $300.
Thank you for clairfying this though.
Artic- I know you can redrill stock but I am going to take this chance to upgrade the brakes while I am at it.
Old Apr 18, 2005 | 09:39 AM
  #64
cooch's Avatar
this is a question im guessing has been answered alot but i thought you can just use z32 5 lug hubs and they are direct bolt in..im guessing this may be wrong?-Brad
Old Apr 18, 2005 | 04:13 PM
  #65
FRONT
Rear
Thanks
Levi
Not to be an ***, but read two posts above you. It states right here that NA Z32 hubs will work on our car in the rear only. Please read the thread more carefully next time.
Old Apr 19, 2005 | 01:40 PM
  #66
cooch's Avatar
i was just trying to confirm it...sorry if i dont comprehend as well as others
Old Apr 20, 2005 | 12:36 AM
  #67
It was stated clearly. I dunno how more clearly it could be put.
Old May 14, 2005 | 01:28 AM
  #68
i was planning on getting the 4 lug to 5 lug spacer things but i was reading around and i saw that Arctic dragon said "don't get the 4-5 lug spacer deal. Too big and unnccesary"...so what exactaly is wrong with them?...i see that GTO makes some btw...
Old May 14, 2005 | 01:31 PM
  #69
It add both unsrung weight and rotating mass, both of which are detrimental to handling.
Old May 14, 2005 | 09:02 PM
  #70
thats the only downsides?...or are there some kind of reliability issues?...cuz in that case i can make up the weight with rims, lugs...etc...cuz this is hella cheaper than buying hubs...
Old Aug 3, 2005 | 09:04 AM
  #71
BigVinnie's Avatar
Why is it, this write to me seems so confusing.
It would of been much easier to just use the 1986 z31/turbo 5lug, to convert over to the s13.
Parts are cheaper and easier to find.
Old Aug 3, 2005 | 11:57 PM
  #72
rotating mass only applies to wheels and bigger brakes.
Hubs are about the same size in diameter.
weight is about 2 ounces.
then again you have no idea what you are talking about.
Old Aug 5, 2005 | 08:57 AM
  #73
KarateBoy's Avatar
You can also use the 300zx hubs but you need their spindle.
Old Aug 5, 2005 | 09:33 AM
  #74
BigVinnie's Avatar
Here are the parts and numbers they may vary slightly from the z31/turbo to the s13...
Old Nov 13, 2005 | 02:46 AM
  #75
iroc07's Avatar
that stuff from the Z31 doesnt look right????? I could be wrong cause its kinda confusing, but have you used these parts? or did it just look like you think they will work? wondering cause I know where a Z31 is sitting and I could get the whole conversion off of it for not much $$$$ and hook up someone on here.
