Anyone know how to remove rear hub from complete spindle?
Hey Guys.
I just purchased a 96 240sx base model. I am going to do a 5 lug conversion for my car. I already have the front hubs and I won a set of rear 5 lug spindles from eBay. My question is, is there a way to remove just the hub from the rear spindles, or am I going to have to replace the entire spindle assembly? I examined the spindles a little, and it doesn't look like the hub just pulls right off, but I may be wrong. Even if I have to replace the entire spindle assembly, how would I get to the bearings to see if they need regreasing or anything?
Any help you guys can give is greatly appreciated.
correct me if i'm wrong anyone ,but as i recall the s14 rear hubs are like a s13.
they have 4 bolts that you unbolt from the inside. you will see the stud side if you remove the rotor. you have to remove the larger nut and cotter pin from the axle end. it is a 36 if i remember correctly.and the 4 bolts i spoke of earlier. then it should pop off.
anyone else know?
don't work on may s14's mostly 13's.
anyone else know?
Toys
Dec 24, 2003 08:36 PM
