brake pads, lines, bled
Old Nov 28, 2003 | 12:47 PM
tenggis's Avatar
i replaced my brake pads with hawk pads bought from tirerack.com. and my brake lines with steel braided lines bought also from tirerack. then i bled the calipers. i haven't done this before so it took like 5 hours. i started with the right back brake. i couldn't make the piston go inside. went out and bought a clamp, still couldn't make it go in. called someone and he told me to turn the piston clockwise and use the clamp at the same time. this was a pain in the ***. on the second brake i tried just turning the piston and it worked. i didn't have to use the clamp. on the front i had to use the clamp. the front was easy. i had someone help me bleed the brakes. over all it was an easy upgrade. i still haven't had a chance to ride my car so i can't tell u the difference yet. i'll write later how my car performs. later
Old Nov 29, 2003 | 02:36 AM
Re: brake pads, lines, bled
Well at least you got the job finished
Let us know your take on the Hawk pads, and what brand steel brake lines are they?
bodiesenmotion
Feb 17, 2006 12:30 AM
PissonH
Jun 26, 2004 10:45 AM
jdmsoarer
Apr 21, 2004 12:49 PM
jdmsoarer
Apr 17, 2004 10:59 AM
jdmsoarer
Apr 6, 2004 05:56 PM
