Brakes are locking up....Help!
Old Apr 8, 2003 | 12:29 PM
DETurbine's Avatar
Exclamation Brakes are locking up....Help!
Yeah I just recently have been having a problem with my brakes. Here is what happens; The brakes are fine for one second and then every once and a while the brakes will seize up and lock my front brakes ( when I'm driving), so I turned my car off, then pumped my brakes ( the pedal just got stiffer every time I pumped), then after they were as stiff as they could get I let off the pedal and then it made a weird sound (like a farting sound) I then turned the car back on and they worked a little better . I haven't had the chance to look at them but I will in the next couple of days.....I just wanted to know if anyone on the board has had the same problem or if they just know what it is. I think it is either one of three things : (1) brake booster (2) master cylinder (3) something with the caliper. Does anyone have
a clue of what is happening?
Old Apr 9, 2003 | 08:30 AM
DETurbine's Avatar
Never mind I found out what the problem was. It was the calipers, the seal around them was ripped and it was letting in air and building up the pressure. I replaced those and I put in some new steel braided brake lines.
whowutwut
Feb 10, 2008 05:30 PM
2fast4y0u
Sep 29, 2005 12:34 AM
swiftstyles
May 4, 2005 11:05 PM
swiftstyles
Apr 15, 2005 08:43 AM
lanseri
Oct 8, 2004 08:09 AM
