tapping noise?
Old Mar 21, 2003 | 09:15 AM
dkdeleon's Avatar
tapping noise?
Hey guys I got a tapping noise coming from under the valve cover , I retorque the valve clamps but that did'nt work it only taps when it rev's to change gears, can anyone help??????
Old Mar 21, 2003 | 01:38 PM
rudeboy's Avatar
mine did that too...then i readjusted the cam timing a little bit...went right away...
Old Mar 28, 2003 | 03:28 AM
dkdeleon's Avatar
was it on a sohc or dohc ? mine is dohc
Old Mar 28, 2003 | 01:24 PM
rudeboy's Avatar
mine is single.....but the same math should break down yours...old age will do it all the time
Old Apr 13, 2003 | 04:18 AM
dkdeleon's Avatar
In cam timeing I assume you meen adjusting the timeing to a certain degree ??
Old Apr 13, 2003 | 07:48 AM
rudeboy's Avatar
that and the ignition timing .
Old Apr 21, 2003 | 02:37 PM
dkdeleon's Avatar
can you explain the easy'st way to addjust cam timing on a dohc 91 240sx ka24de thanx
Old Apr 21, 2003 | 04:08 PM
Spec240sx's Avatar
A DOHC does not have the SOHC ability to adjust. That IS the beni of a SOHC.
The tapping can easily be the tensioner is shot and the chain is slapping the housing. If you have put at least 60k on it or have over 120k on the motor and you suspect the chain has never been done > > > > Do it... There is a good FAQ at the www.********** site. And Alot of info on Fresh Alloy...
Dec 1, 2004 04:52 PM
89s13drifter
Oct 12, 2004 10:05 PM
shawneeboy
Jun 4, 2003 07:57 PM
SilvaPwr
Oct 17, 2002 02:02 PM
drifties151
Oct 8, 2002 12:30 PM
